msiminoff
Jun 10, 2013Explorer II
This is the primary advantage of mppt. It makes using higher voltage panels, or 12V panels in series possible.Yes, and this also means that you can (potentially) charge for more time every day because the panel voltage will be above battery voltage earlier and later.
More Amps X more hours = more Amp-hours.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
