HiTech
Jun 10, 2013Explorer
Salvo wrote:
Hours are the same, but amps are 5 to 8% higher with mppt (under typical conditions).
The graph with mppt flat topping is not caused by amps clipping but due to rising panel temperature reducing the mppt controller's voltage headroom needed for operation. Components: Kyrocera 130W, 12V panel and Blue Sky 2512i charge controller.
Edit, battery voltage held constant at 12.25 to 12.35V.![]()
SalBFL13 wrote:
The hours are the same and the amps the same, so how can you have more AH? Confusing what is meant. ISTR Salvo got some "flat topping" of his curve using MPPT which would do that, but that had something to do with amps clipping so doesn't count?
What does MPPT vs. PWM look like for dawn to dusk? Those ends of the graph are of interest too.
Jim
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
