3_tons
Jun 10, 2013Explorer III
msiminoff wrote:This is the primary advantage of mppt. It makes using higher voltage panels, or 12V panels in series possible.Yes, and this also means that you can (potentially) charge for more time every day because the panel voltage will be above battery voltage earlier and later.
More Amps X more hours = more Amp-hours.
Mark, Well stated! I have two separate systems; 12v panels with PWM and 24v panels with MPPT, all totaling 440w, and have found this to be true. The MPPT continues the push (per onboard metering). MPPT can (most often in my case) help to 'compress' recovery times (an important aspect in winter months) thus maximize available battery storage capacity.
3 tons
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
