Vintage465
Jun 11, 2020Nomad
BFL13 wrote:Vintage465 wrote:
All great info. Personally, I need the best charging when it's cold. I like to winter camp and the recharging in the morning when it's clear and cold is what I need. I think when It is hot thru the night I will have the fantastic fan on and the drain that it has will be overcome the following morning with the solar before it get's hot.
That is why they say to add up your rated Vocs in a series string and then x 1.25 for margin for when it is cold out. If you go over the controller's Voc limit, it fries--no second chances!
I think I'm not in danger of exceeding my Voc's.........but I'd be more sure if I knew what Voc's are. Not real into acronyms here. I'm under the wattage, amps and voltage for what my controller is rated for. All panels in parallel.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
