CA_Traveler's avatar
CA_Traveler
Explorer III
Jun 10, 2020
Solar Controllers PWM MPPT Temperature Performance
It’s often stated that PWM performs better than MPPT up to 10% at higher temperatures which is a statement that’s largely out of context and basically incorrect. For anything other than for simple solar arrays the performance of the two controllers is the same.
I certainly agree that if you only only consider the panel temperature coefficients panel voltage goes down with increasing temperature and vice versa. The current changes but by by a much smaller percentage. I guess this is the source of the misinformation.
Increasing temperature moves the maximum power point down (less power) and to the left (less voltage) and the IR curve also shifts to the left. This results in decreasing power available for charging and at both lower temperatures and higher temperatures MPPT has the advantage.
IN 2014 when I was gearing up for solar I didn’t fully understand the issue which is explained in the “Victron White Paper Which solar charge controller: PWM or MPPT?”. If interested the document is not long or deeply technical. Enjoy
Click here: https://www.victronenergy.com/blog/2014/07/21/which-solar-charge-controller-pwm-or-mppt/
Then just under the Victron controller picture click on the link to download the pdf file.
  • I found this video to be very helpful. Good luck and we love to talk to anyone about this. I have four 12v batteries on a 100watt panel in series and so far am impress what I can do.
    https://youtu.be/kF_cVEYxj3E
  • Vintage465 wrote:
    All great info. Personally, I need the best charging when it's cold. I like to winter camp and the recharging in the morning when it's clear and cold is what I need. I think when It is hot thru the night I will have the fantastic fan on and the drain that it has will be overcome the following morning with the solar before it get's hot.
    That is why they say to add up your rated Vocs in a series string and then x 1.25 for margin for when it is cold out. If you go over the controller's Voc limit, it fries--no second chances!
    I think I'm not in danger of exceeding my Voc's.........but I'd be more sure if I knew what Voc's are. Not real into acronyms here. I'm under the wattage, amps and voltage for what my controller is rated for. All panels in parallel.
  • The specs for your controller will include a voltage limit. The voltage used for that limit is the open circuit voltage (Voc) of your panels added up if they are in series or for just one if they are in parallel.
    Those panel spec Vocs are for 25C temperature (about 77F) and voltage goes up when it is colder than that. So they warn to allow more than rated Voc when camping in the cold so you don't hit that total Voc limit and fry your controller.
  • Morningstar has a calculator that will check your setup. On their website search String Calculator. If they don't have your panel you can enter it's specs. They only support their calculators and if you don't have one choose something like the MPPT 60. You'll get the information for the panels including Voc etc. With a non Morningstar controller the panel hookup information may not be correct but there is still a lot of good information.
