ajriding's avatar
ajriding
Explorer II
Jul 05, 2013
Solar Diode?
I'm having dead battery problems and have not found the source. I suspect the diode could be bad from the solar trickle charger.
I still have current off the solar panel (although 19v seems high) measured off the wiring.
Can the diode still work (all current to pass) when shorted out (blown)?
notes: My batteries go dead quick, overnight only, and after 1 or 2 days are down to 1 volt. So, a short would probably have caused a fire, and I have unplugged everything else that I know of. The issue killed a pair of marine batteries in my RV. New batteries, and I thought the problem was solved and they were dead soon. I am unwilling to try different things for fear or damaging the new batteries further. I installed a small charge controller before all this, the solar ran through it, now have it unhooked and just have the charge controller hooked to battery, thus not controlling anything. I think the solar panel is similar to this one http://www.gumtree.com.au/s-ad/athelstone/other-home-garden/10w-10-watt-16v-solar-panel-rv-direct-battery-charger/1019816706 , though should be a 12v model...
Fridge was one thing not going through breaker box, but now is going through it - dosent seem to be issue and fridge has an on/off switch anyway. No CO2 monitors or anything either. The only drain on RV coach batteries is the radio memory, which has been the case for 10+ years (but not the radio main power). and The power drivers seat is also hooked up to the RV batteries. Both radio and seat work, so not suspect.
