cannesdo's avatar
cannesdo
Solar discussion continued..
That thread appears to have been closed and I can't add additional information. Addressing this to time2roll...Thanks for your post. I have a better sense of things now. Agreed...just need to figure out what you need...decide what it's worth to you. Easier to invest in a project like this since it pays for itself.
I just checked out my owner's manual. This inverter/3-stage charger unit is pretty great. Lots of built in protection. It charges according to battery temperature as well and has a battery type selection which was, fortunately, in the right position. The battery bank's total amp hours setting...I didn't take note of it when I first got into it as I was trying to figure out how to operate the settings but it's definitely set correctly now (actually my battery amp hours total about 368 but the only options are 300 and 400. If that was set too high it may have overcharged them.
I *can* turn my charger off via this panel. I also found the instructions for equalizing. I'm going to do that tomorrow. Then I'll turn off the water heater/fridge/charger and test again to see how long it takes for the battery status to go from high to medium under the same conditions (without shore power).
The manual says marine batteries are acceptable but recommends true deep cell or golf cart deep cell. I was thinking that with 200 Ah 6v batteries you'd have 400v so the total Ah of 4 6v golf batteries won't be much higher than 4 12v deep cell batteries. So what's the advantage? They last longer? This gives me only 200v to play with. How do you know when you're at 50%? I do have green, orange and red lights on the control panel. Nothing below orange?
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 17, 2026
