mockturtle's avatar
mockturtle
Explorer II
Feb 16, 2020
Solar energy when battery disconnect is applied
My ignorance of solar energy and controllers is colossal. I'm planning to leave my RV for a few weeks with the house batteries disconnected to avoid dead batteries when I return. What will happen to the solar energy from my 2-100W panels during this time? If the battery controllers work off the battery how will the energy be controlled?
  • You could leave it all connected and let the solar look after the batteries, but there is a chance the float voltage will be wrong and cause the batteries to lose "water".
    First disconnect the array from the controller by taking out the two wires in the controller's "array" terminals. Now you can disconnect the battery bank by removing the wires on the battery posts, including the ones linking the two batteries.
    That will prevent the two from interacting while not being on a charger, and will make sure there is no draw on them. On return, hook up the batteries first, then put the two wires back into the controller's array terminals.
    Put red tape on all the wires on the pos posts. Take a photo of the battery bank with the wires still on it, so you will put them back on the right posts.
    When you get back, bring jumper cables in case the engine battery has run down too far to start the truck. Also, on that, disconnect the 7-pin too if any before leaving.
  • You have solar to avoid dead batteries. Why not just leave them to do their job?
  • You need to VERIFY whether your solar is wired directly to batteries or is "down-stream" of the battery disconnect switch.
    It could be wired either way.
  • Some types of controllers (MPPT is one) warn against having solar connected to the unit w/o a battery connection. I installed a switch on my controller to disconnect the panel from the controller before disconnecting the battery.
Having RV issues? Connect with others who have been in your shoes.24,318 PostsLatest Activity: Sep 14, 2025
