2oldman wrote:
You have solar to avoid dead batteries.  Why not just leave them to do their job?
This.
Battery disconnects are there to prevent dead batteries due to small parasitic loads when the rig is being stored. As others have noted, many charge controllers MUST be connected to the battery at all times if connected to solar panels. Also, your system may be wired so that the solar is not run through the battery disconnect, but you need to find out for sure before you disconnect those batteries.
Regardless, the panels develops a charge if there is no battery or load, but they will not produce power because no current will flow. You can safely leave the panels out in the sun even if they aren’t connected to anything.
The solar charge controller’s job is to tame panel output and maintain full battery charge  regardless of powers in or out. It will charge the battery full tilt until it is full, then cut back to only the power needed to overcome self-discharge.
Let the solar system do it’s job.
If the system was properly engineered and built, the solar does not pass through the disconnect. But there’s no guarantee of that. We all know of stuff designed by knuckleheads and/or built by idiots, don’t we? BTW, one day when you have to replace that battery, remember, you MUST disconnect the panels first.
