CA Traveler wrote:
valhalla360 wrote:
Unless there is something faulty in his onboard electrical system...there is no point to it.
Engine battery doesn't need solar to stay charged and it's simpler and more reliable to have a connection to the charging system for the house batteries with a disconnect.
It's actually common for the chassis battery to not be charged from the house charger. Then there is battery self discharge and perhaps loads that can't be switched off as supplied by the mfg.
And while an alternate charging method might be simplier we would then be denied the fun of responding to this thread.
I would consider a starter battery with loads that can't be shut off to be a faulty system...at least if they are large enough to discharge the battery in under a week. If the battery is simply self discharging in under a week...again, something is faulty.
If he's parked long term, much simpler to run a line to the charger with a disconnect switch and turn that on for a few hours every so often as opposed to setting up and moving a solar array several times a day as indicated.
So other than to play with a new toy to see what it does, it serves no practical purpose.
Of course, there is the fun of discussing...but I doubt that's why the guy set up the solar array. ;)
