brulaz
Apr 16, 2018Explorer
pirlbeck wrote:
My main reason for wanting a MPPT controller was to be able to parallel at least 2 of the panels so I don't have excessive voltage drop in the factory 12ga wiring.
You intend to increase the array voltage by putting two panels in series and then paralleling the two strings of two.
IIRC the Bogart has a max V of 55V, and if the panel's Voc increases by 0.35V per C drop in temperature, you could exceed the Bogart's limit with two panels in series up in Alaska.
50-60V max is pretty typical for PWM. But most mppts can handle 100V input.
And I agree, the second panel is prolly the closest. When I looked for a matching parallel panel for my rig, I ensured it had the same number and type of cells (poly vs mono) and that the Vmp @25C was as close as possible.
A google search using "Vmp 16.7 Solar" reveals a couple of exact matches. Maybe not as cheap as what you're looking at though.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
