pirlbeck
Apr 16, 2018Explorer
BFL13 wrote:pirlbeck wrote:BFL13 wrote:
So stay with poly for your plan to go in series.
So you are saying my KC50 panels are poly? Was poly the original solar panel technology? These are older panels.....maybe 10-15 years old so that would likely make them poly?
Thanks!
Multi is not mono as you already noted. Polys are usually all blue, while monos are often black and seem to usually have big white diamonds between the cell corners--very distinctive.
http://www.wegosolar.com/categories.php?category=Solar-Panels
I am confused.....so there are 3 types of panels? Multi, poly and mono? Or is what Kyocera referred to as mulitcrystalline the same as poly?
Mine are blue and do not have the white diamonds.
Thanks for your help and patience.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
