Tom_M1
Apr 16, 2018Explorer
pirlbeck wrote:You do not need fuses. If a panel has an Isc of 3 amps and you put a 5 amp fuse in the circuit, a short would not blow the fuse because the panel can only produce 3 amps.
Also, what size fuse(s) would I need for either way of wiring?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
