time2roll
Dec 26, 2015Nomad
BFL13 wrote:smkettner wrote:
IMO float is good in all conditions. Most alternators drop voltage with time based on heat or are controlled by the main ECM.
Does "all conditions" include when you will be doing an "incomplete recharge" by dropping to float, when you could have reached "full" before dark if you had stayed at Vabs?
??? Float is best when fully charged. Float is also good when battery has somehow not fully charged.
The alternative (see OP) is not more Absorption but rather to just turn the solar power off. Yes IMO float is better than off in ALL conditions.
Yes it is best to get the battery 100% before float and that does require a very good controller to adjust depending on conditions.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: May 01, 2026
