Almot
Nov 06, 2013Explorer III
Hard to suggest the wattage without knowing the battery drain due to radio and other devices connected. With battery disconnected 2W is enough to stop self-discharge. With radio on standby... who knows? Maybe 10W, maybe 20W. Shouldn't need more than 20W.
Having said this, I would not leave anything connected on any vehicle left unattended for a week, this includes solar charger. Instead, I would either install a cut-off switch and disconnect the battery - or just do nothing if it's only a week. When fully charged and disconnected, truck battery can be left for at least 4-6 weeks.
Small charger under windshield may fail when it's hot - plastic casing just melts down, or fail due to corrosion or cr-appy Chinese quality, and you have a truck full of gas.
Bigger charger outside would have panels in aluminum frames and normally would include a controller which can fail, or connections would fail, and there is a higher current than in small chargers so there is more fire risk - not from the panel and controller but from a spark on temporary clamps on battery or cig lighter.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
