40-42 degrees is indeed a bit too warm for the cold foods section. I think 38-40 degrees is the recommended range. I like ours around 36 degrees and I usually get 34-36 degrees with the thermostat set to 4 on it's 1 to 5 scale. However, I have seen our RV refrigerator's interior temperature climb if the RV wasn't leveled close enough.
What themostat setting did you have the refrigerator set to such that you were seeing the 40-42 degree interior temperatures? Was the refrigerator being heated electrically or with propane at the time? Some folks in the forums have stated that RV absorption refrigerators seem to cool better when on propane.
