Your figures are not in dispute. The problem is you continue to ignore that a PWM controller CAN NOT use the full power rating of a solar panel. My panels for instance have an operating voltage of 18 volts and a maximum power current under load of 8.88 amps....giving each panel a specified rating of 160 Watts at maximum power point , which occurs at 18 volts. A PWM charge controller wastes any voltage (as heat) that is above the battery under charge voltage. The MPPT controller does NOT waste that excess voltage, and is using the full specified wattage the panel is capable of putting out. These facts have nothing to do with the operating conditions or temperature of the panel but have everything to do with the way MPPT uses the panel's full potential over the PWM controller.
PS: even given your resulting conclusion to be accurate, I certainly would not consider an extra amp of charge current to be " teeny weeny " ..........for my particular installation that is over two extra amps per hour per day's charge and can be quite significant for some RVers' boon dock operations.
