pianotuna wrote:
Hi icanon,
There's the rub. Unless the existing battery is nearly new, then adding an additional one may be a problem. That means replacing both.
For small capacity battery banks 1.5 watts of solar per amp-hour of storage would be a good point to aim at.
icanon wrote:
Doug, adding another battery sounds good to me, could you suggest make and model?
Thanks pianotuna
My battery is two years old will be three next summer, willing to change for two batteries. Deciding on which and what batteries to go with? Keep in mind this is a 3 - 4 day adventure and for minimum TT use as I don't need much.
