I have an older Class B motorhome and have been thinking about solar. I can boondock now for 2 days before I have to recharge my 125ah battery. The only thing that draws power is the 12V fridge whic...
150 watts is a great start to the solar system. Also the PWM solar controller is fairly in-expensive, and will help turn on and off the solar charger at the proper voltages.
Some UV rated grey direct burieal wire and 2' of 2" angle aluminum cut into 4 each 6" long brackets will complete the material list. I used plenty of rubber roof sealant to mount the brackets, and 3 #10 screws into the roof.
Fred.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
