I have an older Class B motorhome and have been thinking about solar. I can boondock now for 2 days before I have to recharge my 125ah battery. The only thing that draws power is the 12V fridge whic...
Several have said that I should get 2 panels to total the necessary watts needed. I have no problem with that but when I look at the specs for lower watt panels the IMP goes way down also the volts. What is the effect on charging the batts? Also that means more brackets and more wire and more holes in the roof.
Mick
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
