MickD
May 20, 2013Explorer
Solar Help
I have an older Class B motorhome and have been thinking about solar. I can boondock now for 2 days before I have to recharge my 125ah battery. The only thing that draws power is the 12V fridge whic...
MickD wrote:As long as they are nominal 12v panels they will be fine. Just make sure total Isc does not exceed controller rating.
Several have said that I should get 2 panels to total the necessary watts needed. I have no problem with that but when I look at the specs for lower watt panels the IMP goes way down also the volts. What is the effect on charging the batts? Also that means more brackets and more wire and more holes in the roof.
Mick
