I have an older Class B motorhome and have been thinking about solar. I can boondock now for 2 days before I have to recharge my 125ah battery. The only thing that draws power is the 12V fridge whic...
I = current (amps) V = Voltage mp = Maximum Power. oc = Open Circuit sc = Short Circuit
You really want to watch Isc or maximum short circuit amps so you get the proper rated controller.
Generally Imp x Vmp = panel rating in watts.
1.16 & 17.4 seems like a 20w panel not 90w.
Basically you are buying amps. The I (amps) is what you will get into the battery. The controller basically clips voltage down to what is needed to properly charge and maintain the battery.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
