I have an older Class B motorhome and have been thinking about solar. I can boondock now for 2 days before I have to recharge my 125ah battery. The only thing that draws power is the 12V fridge whic...
Salvo , yes it is simplified, but the object is to just get a WAG on "expected max amps" so you can pick the amps size for the controller you will need. (You still need to get the input voltage rating business right too so you don't fry the controller with that)
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
