pianotuna's avatar
pianotuna
Nomad III
Aug 26, 2018
solar in the rain.
Hi,
Finally a day that is smoky and rainy. Output to the (hungry) battery bank is 3.3 amps at 1:00 p.m. local time on August 26, 2018.
Panels are from 2005 (Unisolar) and are connected in series parallel with an input voltage of 33 to a Blue Sky 3024 di MPPT controller. This is a flat fixed installation of 256 watts. The wire from the panels to a combiner box is 4 #12 (dual wires to each panel). From the combiner box to the controller is #10 (prewire from factory). From the controller to the dual battery bank is #8 with a 25 amp fuse. There is a catastrophic failure fuse at the positive post on each of the dual banks. The batteries are 4 used telecom jars, wired in a balanced manner, with an OEM capacity of 556 amp-hours @ as volts.
  • Almot's avatar
    Almot
    Explorer III
    Don is pretty far North, I think 50-something.
  • I do not thnk PTs Unisolars are amorphorus.
    I've seen various outputs from 0 to 3 amps during rain events around noon here at 32' N, from 198 total watts. 130 watts of a poly framed Kyocera and 68 watts of Amorphorus pvl-68.
    Lots of variables as to what one could/should expect with cloudcover and or rain.
  • Almot's avatar
    Almot
    Explorer III
    3A from 256W in rain is impressive, amorphous Unisolar must have some sweet spot for this kind of conditions. Well, it's still summer, a lot of sun behind those clouds.
  • Twelve, ten and eight gauge might be a slight bit small depending on the distances but during rainy and smokey conditions, that’s not bad at all. Are you in bulk, absorption or float stage?
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 07, 2025
