VAHillbilly's avatar
VAHillbilly
Solar Install question
I am planning to install two 160 watt panels on the roof of a Class C RV. I would like to make the installation where I can add another 160 watt panel if needed in the future. The wiring will be in parallel down to a MPPT controller. I anticipate about a 20' run of wire from the roof to the controller and then probably less than 3' to the batteries (two 6 volt GC).
I am thinking I should use #6 marine wire from the roof to controller and the same to the batteries. The panels will have what I think is #12 wires to MC4 connectors.
My question is what type connectors or small junction box should I use from the panel pigtails to the #6 wire? Also what type fusing and disconnect switches should I use. Frankly any recommendations for a properly designed system to handle 320 to 480 watts of PV output would be greatly appreciated.
Any recommendations even specific brands, part numbers etc. would be most helpful. I am a bit of a neophyte on this but when I see factory mounted systems using 12 gauge wire and low end controllers I know there has to be a better way.
Having RV issues? Connect with others who have been in your shoes.24,333 PostsLatest Activity: Nov 06, 2025
