EMD360's avatar
EMD360
Solar install so far
When I replaced the vent fan in the bathroom I saw the skimpy roof build first hand. I couldn’t see how drilling into a thin layer of fiberglass and luan then into styrofoam would be a good mount for my panels so I bolted them to 8’ galvanized angle iron instead and will screw the t-brackets to the edge above the gutters on each side.
The t-brackets I’m using were the thickest I could find but I think I will need some reinforcement under the angles to help support the weight. I think adhesive will be ok for that. I mounted the panels first then got them up on the roof. My plan was to use y mc4 connectors and parallel the two panels. I tried to take the wires through the back side of the grate but I could not bend them to get them down the shaft. So I ended up sealing the holes with eternabond and the vent grill with more Eternabond around the wires sticking through. Of course I got the wires tangled so had to unhook them to lay them straight.
The wires are routed through the refrigerator vent. I found that the vent cover was too large to fit over the rail. So I turned it around so it fit on one side then cut it to slip over the rail. I figure it’s not crucial to have the cover slant into the wind.
I was able to get the wires into the refrigerator compartment but now I think I have to drill a hole in the bottom and hope I don’t hit the water tank and then fish them through the small slot between the tank and the basement area where I’m mounting the baby box and the controller.
I’m going to take advantage of the edge beams to secure the angles.
I also think it will be easier to remove the panels to clean the roof etc. plus they have some ventilation. Seems like the air conditioner will help block road wind too. Here is what it looks like so far.
If anyone has any advice especially on how to get the wires into the basement area I’d really appreciate it.
  • Subscribing. I've never dealt with solar and to be honest, when I look into it I get confused. The mechanical side, such as installation of the panels as you show, is the "fun" part for me. The wiring, control boxes (whatever) stump me. As an engineer by trade, you'd think it wouldn't. But I've spent 30 years doing manufacturing engineering...factory layouts, etc. Nothing electrical!!!
    Anyway, so far I like your install...I'll follow along.
Having RV issues? Connect with others who have been in your shoes.24,316 PostsLatest Activity: Sep 13, 2025
