CA_Traveler
Dec 26, 2014Explorer III
Yes, Midnight makes the equipment. I'll post the link later.
However be advised that while the MPPT 60 manual indicates you can use a double pole switch to disconnect there is no mention of connecting. But hopefully connecting would be OK. I'm leary because what if the battery pole disconnects just before the panel pole? Maybe a problem and maybe not.
I was considering that for a update until the recent manual update indicating the controller can be damaged if the battery is disconnected while the controller is charging.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
