jhilley
Dec 26, 2014Explorer
RoyB wrote:
I am still learning what to do with my future solar panel plans...
What does adding the panels outputs in series gain you. Your solar panel controller than has to deal with a very high DC voltage which all gets converted down to smart mode DC Voltages (14.4VDC etc) when charging your batteries. I think the MPPT 60 can only accept a maximum of 48VDC. What happens if you exceed the 48VDC Input coming from the panels in high sun?
Perhaps it is easier for the solar controller to regulate at a constant smart mode DC voltage output with higher input DC voltage levels... When you place solar panels is series I know the DC VOLTAGE will increase - what does the DC current do... Does it also increase... I'm comparing this to two 6VDC 225AH batteries in series. You get 12VDC out of this but the AHs stays the same 225AHs.
My goal I think is to get as much current as possible at the smart mode DC charging voltages feeding the batteries to meet the 17-20AMPS per battery in the bank if I need to get them re-charged in a quick three hour high sun period.
I need to do some more reading I think hehe...
Roy Ken
The Morningstar MPPT 60 can handle up to 150 volts. They also have a 600 volt model. The current is that of a single panel. The big advantage as mentioned, is that you can use smaller gauge cable from panels to controller with less voltage drop.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
