KJINTF
Dec 26, 2014Explorer
Nice install!
Got a good laugh looking at that Fantastic Fan cover - no need for an external cover on that one
As 2oldman says not very many series installations - there are many advantages as well as a few compromises. The odd number of three panels makes a series parallel install a bit difficult.
You should easily see very close to 50amps getting to the loads - My little 550 watt install gives me 40 amps to the loads under good conditions
Hope you left room for the RS232 cable to the MPPT 60 - to upgrade software you need a serial connection it will not work with the Ethernet alone
Did I miss the voltage sense and Battery temp probe connections?
Yes the TS MPPT 60 can handle up a a max of 150Vdc - Take a closer look at the manual there are several things that down grade that 150VDC max to as low as 100Vdc
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 24, 2026
