CA_Traveler
Dec 26, 2014Explorer III
jhilley wrote:Good idea and I plan on adding a sign. Also I will disconnect the solar before anyone works on the rig.
Nice install. Maybe you could just put a warning plate on the battery switch. It is handy to have an easy way to cut the battery. Even if you take out the switch,a technician may still pull the negative cable before working on any thing.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
