BFL13
Dec 26, 2014Explorer II
"A disadvantage of the MPPT 60 is that the efficiency decreases as the difference between the battery voltage and the array voltage increases."
I have only seen the efficiency curve on a Tracer MPPT that was in its manual linked recently. That one had the efficiency dropping as the controller was maxed out in Voc input.
So there is another efficiency curve running at the same time wrt battery vs panel voltages (panel voltage will be the Vmp as held by the controller)?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
