CA_Traveler
Dec 26, 2014Explorer III
KJINTF wrote:How often does Morningstar updated the firmware on average?
Hope you left room for the RS232 cable to the MPPT 60 - to upgrade software you need a serial connection it will not work with the Ethernet alone
I was hoping to just remove the cover plug in the serial cable every few years or so. Easy to just have access in the storage area but I can run a cable inside. Should I consider bring the cable inside?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
