bka0721
Apr 17, 2015Explorer II
CA Traveler wrote:1X1X1/8" will work very well. Thanks for updating what your progress and improvement are.
The second set of vertical brackets is 1x1x1/8" aluminum, same stock as the horizontal bracket. One bolt connects the two brackets. The picture is not very clear.
The horizontal brackets are secured to the fiberglass roof with VHB tape and #10 SS screws. Dicor is used to ensure there are no leaks due to the screws.
The brackets and panels are not going to move.
Also, Dicor expire whether you use it or not. Saving it won't do it any good. There is a reason what manufacturers "puddle" Dicor. I would use a lot more than you did. It is different than caulking the bathtub. You don't need to be exact.
b
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
