BigWapiti
Jul 24, 2017Explorer
Thanks for the quick reply. I did go through and check connections - it's pretty tight in there, but everything seems solid. I went up on the roof and disconnected and reconnected the plug. Seems tight.
I checked V at the battery: 13.0
I checked V at the Solar regulator:
BATT terminal: 13.0v
ARRAY terminal: 1.50v
Something I don't quite undersand too on the solar regulator -there are four total connections. the two on the left are BATT and ARRAY, shows [--Positive (+)--] above it. The two on the right say the same: BATT and ARRAY, but shows [--Negaive (-)--] above it. The side that shows voltage is the side that says "POSITIVE" .. The other has no V reading. I'm not understanding what is meant by POSITIVE vs NEGATIVE over the two separate terminals for BATT and ARRAY.
I only have one solar panel.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
