cekkk's avatar
cekkk
Solar Maintainers
For the nearly 10 years we have had a camper, I have either removed the battery or had it plugged into power during storage. Now for a period of time it will be in a storage lot. I have a new battery on the A-frame and would like to keep it charged. We have plenty of Sun here in the desert, but I need some advice on what type of solar maintainer will let me attach it to the battery and let me walk away for weeks at a time.
Additionally, this jayco's battery is practically buried on the back of the A-frame. Very difficult to access. Can I run a positive and negative lead out to this maintainer and leave it on at all times, whether the solar maintainer is attached or not? And would it be sufficient to wrap the end of the leads in electrical tape when not in use? Thanks.
  • Thanks, I'll shop a hundred against a portable. Our storage space is as safe as they come.
  • Hi,
    Solar maintainers work--but are far more expensive per watt than doing a 100 panel with a good charge controller.
  • No, electrical tape is not good for this.
    You need a solar controller that is intended for this kind of "battery tender" service.
    And you do not have to connect it directly to the battery; just to a point what is hot all the time.....and the negative to ground (chassis). There won't be a lot of current.
    If you need to run a new wire, get a pair of SAE "battery connectors" from an auto parts store.
    And finally......if you have the batteries fully charged and COMMPLETELY disconnected, they should sit fine for 90 days with no attention at all. If they won't, they probably need to be replaced anyway. If it gets really HOT where you are, 45 days might be a better benchmark.
  • Yes all that will work.
    Although for the effort I recommend about a 100 watt panel and a controller permanently mounted on the roof.
    Portable is fine too as long as it does not walk away in storage.
    I would use an insulated connector over twisting a couple wires and wrapping with tape.
  • My 25 watt/1.4 amp panel from somebody and twenty dollar weatherproof controller from WindyNation keeps my two T125s charged when my Winnie is covered.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
