2Macs's avatar
2Macs
Solar Novice Needs Direction
I keep dreaming up possible modifications for my TT that are sometimes excellent and other times "crazy".
Now, the subject is solar.
I use two 12 volt deep cycle batteries wired in series to power the TT when electricity or generator is not available.
I am considering using solar panel(s)to charge them if dry camping.
My initial research indicates I need a minimum of a 12 volt panel to charge one battery. Do I need 24 volts or larger for two batteries to keep them up and also use power from them at the same time for lighting, water pump and heating, etc?
Now, here is the crazy part. I also have 600 watt and 500 watt power inverters to 110 AC. I can't tell you if they are "pure sine wave" or "modified sine wave" inverters. One is a Rally Model 7294 inverter.
Can I attach these inverters to the batteries in such a way to generate AC to handle a 22 inch LED TV, charge a shaver, a toaster occasionally, or a 900 watt microwave occasionally?
Can I even do this? If I can, what size solar panel(s) do I need?
I did a search in the forum on this subject and did not find any satisfactory answers.
Forum members expertise would be appreciated.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 03, 2026
