eflyersteve's avatar
eflyersteve
Solar on a small TT
I'm looking at a small travel trailer (starcraft satellite 17rb) which is only about 20ft long. Roof is composite one piece without much of a flat area. One thing that I absolutely want on my next RV is solar. I would prefer this be roof mounted if possible with enough battery to dry camp and run lights, water pump, TV, stereo, charge phones and laptop and occasionally run the microwave. The small size of the trailer would seem to bring some challenges because there isn't much area for gathering solar. This may require me to use some carry-out portable panels that I feel are less than ideal (theft mainly).
So my question - is there an ideal minimum roof area on an RV to provide enough room for the required solar panels to accomplish what I want? I'm not restricted to such a small travel trailer if I need to go larger to get enough solar I will, but was curious if someone had already considered this and what conclusions were drawn?
Thanks!
  • eflyersteve wrote:
    Thanks for the replies everyone! I was thinking I would shoot for 400 watts minimum of solar. More curious how easy it is to get 400 watts on such a small roof. Probably isn't easy based on the size of panels. I was looking at 250-280 watt panels which are larger than the 100 watt panels (of course), but it actually might be easier to fit smaller, lower output panels on a small roof so this gives me some ideas.
    I'll see if I can get on the roof of one and see what available areas I have. If needed, I could always try and install as much rooftop and then make up the rest with a portable setup that I would deploy in the mornings and stow before heading out. Second concern will be where to store batteries. I'll likely start with lead but move to a self-built lithium battery eventually.
    Microwave use is not an important requirement compared to all the other things I would like to be able to run, so optionally I can just plan to cook with propane instead in trips without shore power.
    Yes, 24 volt panels have fantastic prices but 12 volts will often fit the footprint better. Look at panel dimensions then cut out some cardboard shapes and go up and see what fits. As mentioned look for potential shading issues. I can tilt in either direction but of course try to place the awing to the south. Consider where you will places a combiner box if you use pwm and where you will send the cable down. Frig vent, stack or roof termination.
  • Thanks for the replies everyone! I was thinking I would shoot for 400 watts minimum of solar. More curious how easy it is to get 400 watts on such a small roof. Probably isn't easy based on the size of panels. I was looking at 250-280 watt panels which are larger than the 100 watt panels (of course), but it actually might be easier to fit smaller, lower output panels on a small roof so this gives me some ideas.
  • I am a huge fan of solar power......it's FREE after the initial costs are paid.
    But.......solar requires sunshine to work.
    If you like a nice, cool shady spot.....the output will disappoint.
    You cannot easily move the trailer around to get some sun with a rooftop, but with a 15' cable from a portable panel, finding a sunny spot becomes less of a challenge.
    A typical 100W solar panel is 47" long by 21" wide.
  • You were probably on the low energy use side of things until you mentioned microwave. It isnt that the micro will consume a ton of amp hours, it's that it has a high current draw. Battery, inverter and cable sizes all go up when trying to power something like that. Having an idea of how may amp hours you use will help determine how much solar you need. If you carry a small generator that could be used for running the heavy items and also cover times of poor sun. A generator and a GOOD converter are an effective means of putting in the heavy amps that the battery wants early in the charge.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
