ajriding
Jan 20, 2019Explorer II
So,if you run in series your voltage goes up and amps down relatively.??
You would do as said, run two in series for 24 volt, then another two for 24 and run those parallel…
What do you have to need so much panels?
I have never thought to run a controller for each panel, as one response mentioned, does that do anything other than information? I run my two 100's into one controller and connect at the controller.
