Shade affects solar a whole lot more than you might expect. To begin with, solar output is much like gas mileage, or horsepower type claims, often somewhat overly optimistic shall we say in the claims. For a flat mounted panel on a good day, figure about 5 amps as a realistic output in good sun, an amp or so more if you tilt it. From here it's all down hill, late in the year, output goes down. A little bit of cloud cover, output drops. Shade on just a portion of your panel, significant power drop. Seeing your output running at only half is fairly common.
Shade of a heavy pine forest often takes my 600 watts of solar from 30 amps down to less than 5. Just for grins I checked my output the other day at Ainsworth state park in the Columbia river gorge, and the output was only 1.7 amps. This was at approximately 2:30pm, light overcast, shade from the canyon wall and heavy forest cover. Solar is great for when it works, but unless you plan your camping around optimizing your solar capture, it's not particularly reliable, or cost effective. On the other hand for me, the simplicity, and quite nature of solar make it worth the installation cost even though it will probably never pay for itself, even though having done all the installation myself it was relatively cheap.
