N-Trouble's avatar
N-Trouble
Solar overcharging batteries
I have a 160W ZAMP Solar package on my 5er I bought a few months back. Now that the days are getting a little longer and the sun a little higher the solar is doing its thing. I have been disconnected from shore power for a few days, and yesterday I noticed my batteries were bubbling which surprised me. I went inside the trailer to look at the solar control panel and found the batteries to be all the way up at 15.4V! Even though the status indicator is green indicating "float" voltage it sure seems that at that voltage level its in equalization phase. Am I wrong in thinking this?
I have the DIP switches on the unit set to 14.4V bulk, 13.4V float, and 15.1V Equalization. The last DIP switch I have set to "manual" equalization.
So why would the controller be pushing 15.4V to the batteries if I have not commanded it to do a manual equalization? And even if I had it seems as though its pushing a higher voltage 15.4V vs what I have it programmed to 15.1V?
  • Is this an MPPT or PWM controller?
    Could be your parasitic load is so low that the controller is not able to "buck" the voltage down enough from the panel.
    If you turn on ~80 watts of loads, where does the voltage settle at, during peak sun?
Having RV issues? Connect with others who have been in your shoes.24,315 PostsLatest Activity: Sep 09, 2025
