reddfox77
Aug 11, 2013Explorer
Solar panals
Can some one tell me how solar panels work? I have one in a class A that I bought used. Put a new battery in it and dont know how it works. Does a switch need turned on to make it work?
Almot wrote:Tom_M wrote:
The photo of the Power Guard is displaying volts and reads about 11.6 volts which is low.
Right! That small switch is in Volts, I didn't notice. He should check the current and voltage on the same meter in absence of loads. Pull out all the fuses. Measuring the output with multimeter near the battery would be my preference though. Also, measuring the battery voltage at rest.
