Rbertalotto
Aug 04, 2013Explorer
Thanks BFL... I'll check the AH reset.
My Trimetric shows -00.3amps (negative) no matter how much energy I try to put back into the battery. I believe the -00.3amps is the propane and CO2 monitor/alarms as everything else is off.
I've double and triple checked my wiring. It is as the manual states. The battery side of the shunt has one #10 wire to the NEG terminal of the battery. Everything else is hooked to the outboard side of the shunt.
I use a four conductor, double twisted pair wire with the proper twists to the proper terminals on the side of the shunt.
My concern is that no mater what I do I can't get the amps to go positive and the voltage stays as 13.2.
The Phocos also came with a digital read out module (Phocos CMM) but I removed it when I installed the Trimetric. It never showed more than 1 amp no matter how much sun was on the panel.
Is this more food for thought?
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
