Rbertalotto
Aug 04, 2013Explorer
The installation manual says to use the same size wire or "larger" than the largest wire connected to the battery.
The largest wire to the battery is #10.....In fact, ALL wires to ground and + are #10.....But it makes sense that the wire should be as large as the "total" of all the wires. There were four #10 wires connected to the negative terminal of the battery. I would think a #4 would compensate for these wires. I'll change that tomorrow.
But the single positive wire that goes to the Centurion converter is only a #10...This wire is only 18" long as the converter sits directly over the battery.
Thanks again!
Will this make a difference? Or do I need the #4 simply for the shunt operation.
Thanks again!
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
