Hi Tom,
Your numbers only work for a 24 volt battery bank. Since it is 12 volt Westend is correct.
I would never buy a controller and run it "flat out". I would never buy a controller that did not have temperature compensation. I would never buy a controller where I could not add an additional panel. Three strikes--and this controller is "out".
Tom_M wrote:
westend wrote:
The input rating of the controller is 20w less than the output of the module. That may or may not be a problem but you may want to check with Tracer before mating to that panel.
The panel is 24 volt. The controller is rated 520 watts for 24 volt so there would be no problem.
