BFL13
Jan 31, 2017Explorer II
I think you mean the panels would be connected to the solar controller in parallel with the 24v power supply being run with 120v input. Not in series.
I think the solar controller would have difficulties sorting out the correct voltage to apply to the panels. Suggest another chat with Morningstar.
If you have shore power to run the power supply, why do you need the solar input at all while that is the case? You can have a disconnect switch between the panels and the controller. Off grid just use the solar input.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
