Chum_lee
Nov 17, 2019Explorer
As others have stated, it most likely came that way from the factory as a trickle charge maintainer. (my '99 Class A has the same thing)
Normally the panel is about 12" square. When clean and new, a reasonable output expectation would be about 8 to 12 watts or at 12 volts nominal, less than one amp which is essentially, . . . . . useless for just about anything other than running a small transistor radio or charging your cell phone. Sorry but don't get your hopes up, you'll need a lot more panel area than that for any type of meaningful solar power generation.
Chum lee
Chum lee
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
