brulaz
Jan 23, 2015Explorer
MrWizard wrote:
the voltage per solar cell is pretty uniform across the industry
BUT the larger the individual cells the more current per cell
all my unisolar panels have the same Number of cells and the same voltage
but i have THREE sizes, and three different wattage ratings
the individual cells are different sizes in each of the three different wattage's
could be the same thing with the 72 195w vs your 60cell 250 watt
your 60 cell panels have bigger cells
what is the dimensions of the cells and the panel
this is where the "efficiency" rating of more expensive higher efficiency panels comes into play, producing more amps/power per cell
Would mono cells be smaller?
My 6x12 195W panels are mono.
From their spec sheet:
125x125mm cells (4.92"x4.92")
1610x808mm total (63.4"x31.8")
Cell efficiency: 17.9%
Module Efficiency: 15.6%
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 11, 2026
