Boon_Docker
Apr 20, 2016Explorer III
Building a high voltage systems in series makes sense if you want to use smaller gauge wire. If you had 1000 watts of solar you would need some pretty hefty wire to the controller in parallel.
400 watts and above = series wired with MPPT controller.
400 watts or less = parallel wired with PWM controller if using 12v panels.
