Almot
Apr 21, 2016Explorer III
2oldman wrote:Sam Spade wrote:My obsession was using the OEM #10 wire from the roof to the basement.
I don't quite understand this obsession with wire size.
x2.
Buy MC4 cable, cut it in half, plug and play. No roof junction box. I have yet to see a plastic box that will stand to all year round heat and UV where I am - and they all look ugly :)
RLS7201 wrote:
The OP has 3, 24 volt, 230 watt panels in series, going to a Outback 60 charge controller. He is contemplating adding another panel or two.
The question is how would you wire it or rewire it and why.
Now I recall that old thread. Should've probably bought TS MPPT 60.
The question is - again - what he is going to wire, "another panel" or "two". And, - what panel(s). There can't be a definitive answer without a defined input. A debate can be. Series, parallel, series-parallel, mismatched or not, thinner/thicker cable, J-box, here we go again, round 4.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
