RLS7201
Apr 21, 2016Explorer II
Almot wrote:2oldman wrote:Sam Spade wrote:My obsession was using the OEM #10 wire from the roof to the basement.
I don't quite understand this obsession with wire size.
x2.
Buy MC4 cable, cut it in half, plug and play. No roof junction box. I have yet to see a plastic box that will stand to all year round heat and UV where I am - and they all look ugly :)RLS7201 wrote:
The OP has 3, 24 volt, 230 watt panels in series, going to a Outback 60 charge controller. He is contemplating adding another panel or two.
The question is how would you wire it or rewire it and why.
Now I recall that old thread. Should've probably bought TS MPPT 60.
The question is - again - what he is going to wire, "another panel" or "two". And, - what panel(s). There can't be a definitive answer without a defined input. A debate can be. Series, parallel, series-parallel, mismatched or not, thinner/thicker cable, J-box, here we go again, round 4.
How about you answer the question twice. Once for one added panel and once for 2 added panels. And before you ask, the added panel(s) will be identical to the panels already in place. Should be simple enough.
Richard
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
